The Edelbrock Torker is an open plenum intake while the Performer is a dual-plane type. Typically, open plenum units are high-rpm racing types while dual planes are more allied to street use. Dyno tests have shown that a typical engine gets more midrange power & torque from the Performer than from the Torker, and on most engines the peak power is virtually the same. It gets complicated a little in that original '70s-version Torkers were big-port 4V types but later, there was a 'Torker-2' that fit small port 2V heads, and guys found by accident that adding the small port intake to the big-port heads allowed all of the benefits of anti-reversion plates with no extra parts (these plates add huge amounts of mid-range torque & street driveability to most engines). The downside of the large mismatch in port size is, around 5500 rpms the mismatched intake falls flat on its face, but if your engine doesn't spend much time in those regions, this is an excellent choice as well. Good luck- Jack DeRyke - PI Boss Wrench.
