when mounting the roof spoiler, which direction should it face? One side is cut in a little deeper..is that the side that should face forward? Also how far back from the leading edge of the engine deck should it mount if measured from the center of the spoiler to front edge of engine deck? Thanks for the advice. Got pics?Big Grin
  • spoiler
I checked it on my GT5. Maybe I'm nuts, but the wing seems identical either way. Same thickness, same dimension. However, as the rear deck is wider at the back end of the car than it is at the front end at the roof line, then the best thing would be to lay it on the car and look at the fit at the mounting points of the wing. See my red arrows!
  • Slide1
The two wings combine to carefully to divert all exiting air from under the car causing it to roll directly against the rear face of the car. THis ensures that the white turns brown within a few hours. This is gresat as it is the only surface on the car that is hard to clean - inside the rear light pods, around the Detomaso Pantera GT5 lettering, the license plate, and the rear bumper. Did I mention how much I like white Cats?
