Each trigger in the dizzy is connected to separate ignition module, each module is connected to a separate coil, the output of each coil is connected to a
coil selector , the output of the coil selector is connected to the center terminal of the distributor cap.
You select which module is running via a switch in the passenger compartment that powers up only one module at a time.
In regards to which module to run, well, it depends upon what you are using the car for. If you're racing the car, let your motor builder specify the module. If you want ultimate reliability for a street car nothing beats a Duraspark module.
