New front brakes fitted to Pantera 4384.
Wilwood 330x28mm SRP Drilled & Vented Rotors with Wilwood Aluminium hats, (machined bore of hats to suit location diameter on IPS hubs).
IPS Aluminium wheel hubs.
Brembo 8 piston Monobloc Indy car calipers. Calipers rebuilt with new seals, titanium piston caps & re-coated locally by High Performance Ceramics with an heat dissipating coating.
regards,
Tony.
