Seems like I am not getting power to either fuse for the highbeams. 1973 Pantera L I'm guessing its the turnsignal stalk switch. Replace or repair? Recommendations? Thanks
Contact SOBill. He used to rebuild them for a very reasonable rate. You also might check the terminal block located in the steering column. Mine had some connectivity issues. The result of someone leaving out the ballast resistor to the ignition which melted most of the insulation the entire length of the wire.
I'm in touch with SOBill. Husker did you do this yourself? Any lessons learned? I'm not around this weekend, but I'd feel better tackling this with you (if/when you might be available).
I got a used one from a Capri parts dealer. I'm available almost every weekend. No lessons learned really. You might want to get a replacement terminal block just in case.
