John,
there "should" be an ID tag in the front boot, atop the foot box (between the power brake booster & firewall) that lists the engine & trans numbers. I say should because mine was missing when I purchased the car.
The numbers are found on the trans & engine in the locations pointed out in the pictures below.
  • Pantera_IDs_001
The VIN for your Pantera "should" be stamped into the chassis in the boot atop the footbox, the ID tag will sit over this stamped number, with a window in the ID tag that allows you to view the VIN below. Besides the VIN number visible through the tags window, the engine & trans numbers will be stamped on the tag itself.
Below is a picture of the VIN number stamped into my chassis, where the ID tag should be located.
  • pantera_vin
