I need a oil pickup tube for my stock rear sump pan. What store? My Pump has a Carter pin in it. Do I take Pin out and put it thru the tube? Also My pump has a Hole on the Bottom Next to the Plate. 2 holes? One on the Side with carter pin. One on the bottom??
