What is the correct oil temperature sender for a Pantera GT5 (280°F gauge)? Also, what thread size is it?
Wilkinson doesn't have them in stock. Do you know the thread size?
(at least, Veglia used on Mangusta and Ferrari/Fiat were M16 thread)
Mine is M14x1.5 and the oil pan is 1/2 NPT. I bought Facet 7.3267 - dipped in a boiling kettle it shows 95°C on the gauge.
I'm told 7588856 also works.
Many thanks indeed! Is the M14x1.5 in the block or the oil cooler?
cheers, Tim.
In the oil pan...I have an M14 to 1/2" adapter. Is this not the original mounting spot?
Yes, it is.
Great, many thanks. Just wanted to make sure. I think the mounting can be in different spots.
Sign In To Reply
