after trying acetone ,mek,lacquer thinner ,which just made a mess. a product called goo gone and an old credit card as a scraper got the job done.keep wetting the surface using old towel @6'' square , let it soak in, then use the card to scrape the surface. it took multiple applications but took all the glue off to the metal. when all the glue was off i then used a little lacquer thinner to prep the metal for the new headliner.
