The sealant that one of the prior owners put on the inside of the tank is deteriorating, so if I have to take the tank out I thought about upgrading it to one with better materials.
Thank you. I am glad to hear that the tank didn’t have any issues and fit well. Most likely will go in this direction. I had thought about having one made in aluminum, but this would be an easier solution.
