I can't comment on aftermarket fiberglas flairs' durability, but figuring the surface area thats bonded with the epoxy and the bond strength possible if done correctly, it seems they should hold for quite a while. Of course, fiberglas of any thickness WILL eventually crack- take a close look at any Corvette sometime. Body twist in Panteras running giant tires may also contribute to the cracking of flairs; after all, it cracks paint and stock body-metal!
