I was asked to display my car at a Memorial Day festival at the VA hospital. There were about 60 vintage vehicles and the Pantera was the 'hot ticket'. All was well until I started to leave. It started right up with the best roar of the crowd then the alternator belt started to squeal. Damn!! It squealed at all speeds until about a mile from home and just as suddenly as it started, it quit. Voltmeter showed 12.5 to 14.5 volts and I couldn't get it to squeal again. My friends will go into it this weekend and we'll change belts and check alt bearings. It was real embarrising to have the car remembered for the squealling departure.
Ed, That's slightly embarrassing, but hardly qualifies as "really bad". Really bad would be when you do a burnout and blow the engine, or a wheel falls off and you grind off the road into a ditch afterwards.
MT GT40 did exactly the same thing and as long as I revved high enough nobody could hear the squeals over the roar! In my case a worn belt, increased tension and readjustment of a slightly off alignment alternator was all that was needed. I'm sure it's nothing major. Soon your pride will be restored! Wink
Mark
