I thought I would post some pictures of a sway bar mount mods I had done. Here's a picture modified sway bar mount on my rear lower A-arm. Someone posted a suggestion to add a support to the sway bar mounts...so when my car was at the fabricators I had him add a 3/16 piece of bar stock to the bottom side of my sway bar mount. It boxed the stock mount. He left the stock nuts on, but drilled a hole through the new piece of bar stock so that you can do a bolt through the mount and actually put a washer an nut on the other side. Since the stock nut is in place it won't crush the original mount because the 3/16 bar stock sits on the stock nut creating a spacer of sorts.
I think this mod will do a few things, stop flex in the actual mount, but also stop oil canning of the mount which might push and pull on the two a-arm tubes that it is welded to when it is actually flexing.
Maybe my stock sway bar will be more effective...should be more responsive?
  • sway_bar_support_mod_2_lower_res_1
This is a picture of my upper rear a-arm. From what I understand it is different than stock?
Supposedly the stock a-arm has the tubes welded directly to the ball joint carrier. Mine looks like the ball joint carrier consists of a piece of plate steel that was added to the outer end of the a-arm. Maybe it has been modified to push the ball joint out to allow more camber adjustment on the rear suspension. Now that I think about it, my upper rear A-arms are the only ones with poly bushings, the rest have rubber. Can anyone tell me if these are a vendor item?
  • Rear_Upper_A-arm_2_low_res
