Guys where the best source at the best $ for a pair of rear axle shafts, just pulled my left side and the bearings spun so its scrap, guess the right wont be far off,cheers panterauk
quote:both the same
quote:What I am not sure is there strength as they are hollow and call me old school I just cant see them been as strong as a solid forged unit
quote:Many of the vendors acquire there Parts from suspicious source's,
quote:I did intend to have the bad one metal sprayed and then re-ground someone said its a good way to repair a shaft if its just marginal wear?,
quote:Can you elaborate on the metal spray solution?
quote:Originally posted by SteveBuchanan:
Can you elaborate on the metal spray solution? It looks like my axles have some damage where the outer bearing contacts the axle. I am thinking it is the cause of some minor play in the assembly after new bearings were installed. If that is the case, then metal spray and grind is a more practical solution than new axles. Thanks.
