For these hub carriers to be used again, they will need another set of Torrington bearing races, pt. no.IR-1016, a custom tubular spacer to go between them, and new 5/8" pivot shafts made from heat treated 4130 (at least 25 Rc), Stress Proof, or more exotic steels.
The original pivot shafts were 16mm. in diameter, but full sized, cold roll 5/8" round bar stock is within .005" of that size and close enough to work with the stock lower control arms.
I FOUND THIS ON EBAY....DOES IT HELP?
