Over the years my cover rear trans cover( visible from rear) has been painted,undercoated and oversprayed. Is this removable for cleaning without springs and things flying? Thanks Tony
It can be tricky, you have one spring for the reverse detent and the shims for the pinion and input shafts,but the main problem is in the reverse idler shaft,sometimes it will stick in the rear cover when removing and that will cause the idler gear to fall in the case,then the ZF needs to be split to repair.
