Mike, I assume that you mean the shaft that is used on the lower A-arm pivot? Do you also have the bushing? Can you send me a picture just to make sure it what I'm thinking they are. I think I need to replace mine...one is galled.
i have some listed on ebay at this time. the shaft measures 10 and a half inches and is the lower shaft thru the A arm.hope this helps. i also have some new bushings. thanks, mike
