Does anyone have any engineering drawings or cad files of the rear uprights or front spindles? I know I did some a very long time ago, but they are long gone.
I would greatly appreciate it...Thanks in advance....Gary
Did you ever get the front spindle diagram with measurements that you were looking for? Is so, can you or someone send me that info as well so that I can compare that with my front spindle?
No, I haven't found anything. I did draw up some brake brackets to mount Wilwood Calipers onto the rear hubs, though....They should be here in a few days...
There are two completely different front spindles- one for pushbuttons & very early '71s, and one for the rest of us thru '87. The early one has a removable wheel spindle and an integral steering arm and the production one is exactly reversed for those two components.
