My rear wiew mirror is useless over 100 mph due to vibrations.
Is there a fix for this, and if yes how does it work?
quote:YES!! THAT'S WHAT I'AM TALK'IN ABOUT!!
Originally posted by Chuck Melton:
A functional and "manly" fix is the use of a spark plug boot. The boot is placed against the windshield and pressed against the mirror arm. I have a photo somewhere on my sites....so give it a try ! No glue necessary. Personally, I notice the vibration goes away above 145.
Chuck
Originally posted by jack deryke:
As you probably know, the inside mirror snaps off and on a steel mount that's glued to the glass, and is held more-or-less tight by stiff flat springs built into the mirror base. If you add some rubber thingy between the mirror & the mount, any looseness is 'shimmed out' and most or all the vibration goes away. Just be careful in adding shim materal- if you crack the glued-on mount off the glass, you get to start over!
You're right- it attaches to the overhead. I was concentrating on something else- shame on me!
Chuck
Originally posted by Kevin Perry:
I wished mine stopped 145 MPH! Mine doesn't stop vibrating until I hit 195!
