Replacing the tires on my 72. I have 245/45r 16's up front and 315/35r 17's out back. I can't find a matching set by anyone. What do u recommend I do? Not wanting to buy 17" wheels up front. Thanks!
quote:They are a little taller and narrower than the 245/45/16's, but work fine.
quote:245/45/16's, Toyo and Bridgestone. Neither of which made 335/35/17's for the rear.
quote:Originally posted by KKOSH:
So the Toyo R888 is a matching set. Is that ok for street use? I won't be driving in the rain. That is the only brand I can find in a matching set.
quote:Here you go Larry
Originally posted by LF - TP 2511:
... I'm thinking because the car is so low, and not an open wheel F-1 car, that the narrower width isn't even noticed ...
