You must have 26in tire,if you go with a 3,77 it will give you 18mph more so that will put you at 163mph,and if you change your 5th gear to .655 you will get 12mph more to get you 175mph.If you can afford to loose some low end a 3,2 Ring and Pinion will put you at 192.3mph I sell all ratios
at www.RBTTRANS.com
[This message has been edited by Lloyd Butfoy (edited 12-22-2000).]
