I love the pictures and thanks for posting.
I had a Hall bar in the car and finally got tired of banging into it and took it out. Sold it to lastpushbutton. Smiler
Not that you would change now and don't consider this as a criticism but did you consider installing the main hoop on the other side of the bulkhead in the engine compartment? If I ever have it all to do again that is where mine is going, with the rearward ties to the rear suspension just like yours and maybe tubes through the rocker panels all the way to the wheel wells.
Fair enough. I remember that I got scared off Halls engine compartment roll bar because it was described as having to modify the fuel tank slightly.
When I talked to them about it they said the modification was taking a hammer and denting it slightly to clear the bar.
I'm pretty sure that Bob at Precision Proformance is the one that builds it. Next time I need to pull the engine I'm going to consider it again.
Gary,
I can't remember but did you weld up all the seams in your car also?
Im not putting a cage in but thought I could gain a far amount of rigidity with stitch welding up all the seams.
My car has some pretty bad gaps where the pieces werent very tight together when they were spot welded. Especially where the rear frame meets the firewall.
Brooke I didn't weld too many seems. Which ones in particular? I did quite a bit of work on the channels under the car. The front ones I replaces the metal and reinforced them with some vertical pieces so I could jack on them. I cleaned tsome things like the bottom back of the frame rail with an additional plate so I could jack there.
When you get this far into the car you can picture the assembly process, the jigs and such. The welds are pretty rough. Some times I wonder if they built this with a a stick welder.
Originally posted by Pittcrew:
Fair enough. No plans anytime soon though, but ya never know when the engine needs to come out right? Wink
PD you cant pull the engine!
Then people in your area will start complaining its too quiet! Wink
I have the neighbors right where I want them. They are terrorized of me. I can't slack off for a minute. Big Grin
