Are 71 seats and early 72 seats the same size - just a different pattern?
Thanks
Yes. But stock upholstery pleats are oriented 90 degrees apart on '71 vs '72. So you must do both seats or risk criticism. '73-up seats are one piece welded frames and totally different, as are 80-up wide body cars. So 4 different seats involved.
Thanks for the information. I would replace both. Is it possible these 71 looking seats seats could be original to a 72? They definitely are original seats and have not been reupholstered. (At least looks that way to me).
Sure could- at the very best of times, Pantera production was chaotic with virtually no sharp cut-off in the use of parts that had been changed or upgraded. Example: my Sept build '72-1/2 Pantera 'L' has a late outside gas filler and the late over-center shifting mechanism.but an early dashboard and early seats. Remember: A. DeTomaso never threw anything away that he could sell!
Sign In To Reply
