Shifting into Reverse is often difficult, needing to jiggle the shifter, etc. to get it to pop into gear. The same is true to a much lesser extent into 2nd. The car has about 30k mi. and had the shocks/springs recently replaced and the ride height was lowered slightly, perhaps making the problem/s worse a bit I think. How easily should it shift into Reverse? Is this just normal for the ZF? If not, any advice as to what I might start looking at? Has anyone else had these same symptoms? Thanks in advance for the help.
