Dr DeRyke et al: Mike Drew wrote in Dec 2000 POCA newsletter (p. 15) about improving shifting by removing the spring-loaded plunger/external centering spring towards the rear of the shifter housing. Do you have any experience with this (not trying to be funny or anything!) and what do you think? Everything is working OK now (just adjusted the trunion bearing up abit after lowering the rear abit to get the trans shift linkage up to clear the half-shaft) but I'm trying to keep up with my friend's built Mustang with a quick automatic.
2316 John
