A Panterapat topic from 6 years ago seems to be an accurate description of what I have...any solutions/recommendations:
posted September 28, 2011 10:37 AM
I have had a persistent problem with a high speed vibration when in a turn. Car drives and track straight as an arrow. When wheels are turned at certain speeds, I get a pulsing virbration (described by tire guy as "axial vibration) back through the steering wheel. I have tried balancing and rebalancing the wheels, to no relief. Some times when in a turn, the vibration eases off. Some times it is persistent. When the wheels are straight - no vibration.
what gives? anybody seen this issue. help
Originally posted by Panterapatt:
I replaced my wheels and tires and the problem disappeared. I could never get to the bottom of the vibration. Concluded it was either a poorly made wheel or bad tire.
Thanks...I have Pantera East 17" Campy replicas and am sure they are true, etc...but I will have them checked. Since it goes away completely sometimes, I'm thinking it is in the bushings or something like that???
