Anyone ever thought about building a sub into the firewall cover like the FORD GT? I was thinking it would be fairly easy if you had a flat firewall kit from Amerisport with the center removable section, you could build up a fibreglass pod for an 8" sub without too much trouble. I just finished putting an 8" JL audio sub in an MG and it sounds really good.
Gary #06984
Gary #06984
Strange timing...I was working on a friend's Diablo last weekend when I noticed his GT40 had the sub on the back firewall. I will eventually have this done, but I don't have a flat firewall, so I will need to figure that out first.
I don't know about you, but I am generally in the car by myself over 90% of the time. My sub is in a box moulded to the passenger footwell. Big and great sound, with a carpet panel over to hide it nicely.
Kids or friends will squeeze in for a short run. But on the rare occasion that I go on a long trip with my wife, I simply pull the whole unit out, disconnect the wires, and change the settings on the system to play without the sub - just using the door speakers and window pillar tweeters. It only takes 1 minute to do this.
Note the amp behind the passenger seat. Crossovers are behind the driver seat. This system is better than my home theatre! The guys at PI gave me excellent advice and built the sub to fit.
  • DSC00231
