The dash end of the tachometer reset doesn’t have enough threads after leather upholstery, is there a replacement end or replacement cable that has longer threads?
For posterity, and for others, all you need to do is get a Dremel and grind down the backside of the fiberglass – until it is thin enough to get the nut to thread on
