Originally posted by JK:
How much weight savings were you able to achieve with the carbon fiber?
Hi JK.
I just talked to my partner at the factory and he is going to weigh both the rear deck lid & frt. panels. - He said on the phone, he thinks the rear weighs less than 10kg. Lets see. i'll post weights as son as he calls back.
The frt. "bonnet,"( decklid ) has the 'new - style' radiator hot air-exits for better air flow, heat disapation....the rear panel, the one posted with the big vents is for my new 'Hi - tech,' carbon-bodied, chrome-moly fully adjustable, ( one Allan Key for all adjustments ) chassis, Grp 4 Replica with all up dry weight of 2200lbs.
- OK . He's weighed both. The front panel unfinished = 8kg (17.6)lbs. The rear panel 13kg (28.6)lbs. I'll get him to weigh the standard parts when he goes home from work today..later, tai
The stock rear deck lid weighs about 65 lbs so you're saving quite a bit of weight.
Is your CF rear hood made of 100% carbon fibre? I would've expected a weight around 13 lbs or so. Wilkinson sells a combo CF-Fibreglass rear deck that weighs around 25 lbs.
Substantial weight savings either way. Thanks.
Josh
Josh
JK, I one time figured up that if you could make the unibody out of Carbon fiber it would only weigh two hundered pounds or so. If you had unlimited money you could make a Pantera that weighed less than 1750 pounds.
Hey JK.
To answer ur question, the rear deck lid construction we talked of is carbon thru out. He says the reason its heavier than expected is its made for road rather than track use, - the race version is lighter.
He is working on the door panels and ram-fed air scoops combined with carbfilter housings at present.....cheers QUOTE]Originally posted by JK:
Josh[/QUOTE]
Just a Quicky :
Footage ( filmed from speeding, minature remote-controlled 2-stage jet turbine chopper ) of 2x Ford GT40's racing down mouintain pass plus final accident, off of new music-video plus "The Making Of" the movie (8mins), plus other MotoHead car 'stuff' to be posted soonest on new website "WheelNuts."
