Get the smallest outside diameter front rubber you can find. This means no more than 17 inch weels up front.
The car hardley tollerate much more than 5 inch of front ground setting, and better still, I prefere 4 inches. Look out so the front tire and wheel does not wheight in at more than 60 pounds.
This is important if road holding is of concern for you.
Goran Malmberg.
