1. Yes, half of the time. Wink
You need to have it in compression mode as opposed to decompression. Pull the #1 cylinder spark plug, put finger over spark plug hole, rotate the engine, use a big socket and breaker bar on crank bolt, until you feel pressure against your finger. Your timing mark should now be around the zero mark.
2. At this point whatever cap post the rotor is pointing to will become the #1 wire. This can be any post. Firing order starts there.
Clear as mud?
Google 'finding TDC' for lots of tips and tricks.
Larry,
You're gonna need some long arms to reach both places at the same time!! Maybe you could hire Clint Eastwood's buddy Clyde, the orangutan from the movie "Every Which Way But Loose". Big Grin
John
