LOL! No, no, no. When you disassemble the column and remove the switch, there is a tab on the inside of the switch that works like a button.
On both of my switches ( I have a spare) if you press that "button" it does not release the switch to the neutral position.
Never mind about the switch. Just figure it out BUT what does the spring on the steering shaft do?
Does it load the turn signal cancelling cam?
