I went to Advance Auto and "borrowed" a kit with multiple ball joint seperation presses.
http://shop.advanceautoparts.c...ece-648617/9150043-P
the "borrowing" process was they charged my CC for a couple hundred dollars, when I returned the kit undamaged they credited the CC for the full amount.
I seperated all the joints in less than 30 minutes with little strain.
Working on mine now. How did you use this tool when there is no lip around the A arm to press against? I read about grinding the top off the ball joint, but don't want to do it if this tool will work, but I don't see how it does.
