I'm not sure that has all been posted together in one, concise message.
So, here it is.
You can use easily available vented Mustang rotors to replace the stock solid rotors on your Pantera.
John Taphorn has reported there IS a replacement 66 Mustang rotor that
is still supplied as a two piece unit. Hub/hat unit and a separate rotor, the
two of them held together with the wheel studs.
This is an important design detail. Read on.
He further states that the shoulder size for the studs in this unit is the same
as the stock Pantera metric studs. Thus, you remove the metric studs from
your OEM rotor, remove the SAE studs from the new rotor, and swap your
stock studs to the new assembly.
Your only mismatch will be the Pantera hub dust cover does not fit the
Mustang hub.
This item is supplied/made by Wagner. They are an old time USA brake system
parts manufacturer, and no doubt tooled up for these Mustang units decades
ago, unlike the new China manufacturers. To save costs, the China units are
all one-piece hub/rotor pieces. Likewise, to save costs, Wagner continues to
make theirs as two piece units - as originally supplied by Ford on the Mustang.
Additionally, John says the separated rotors can, with perhaps some minor
caliper grinding, be a direct swap for the REAR rotors, too. John has done
this install personally.
I have four of these sitting on the shelf, and hope to do the install this winter.
Wagner part # is 60209. Made in the USA!!
RockAuto (located in Wisconsin) website shows they will sell, and ship,
TWO of these to my CA address for $145.89 - not each, but BOTH.
Required dust covers are DORMAN # 13975: $2.98 each.
Go to their home page -
http://tinyurl.com/8afqsp
Click 'part number search', punch in 'BD60209' (leave the other selection
windows blank) and you're there.
  • Picture_7
In case you haven't noticed, it's already winter.
Yeah, yeah.... Wink
I DO plan on full documentation of this. It will make a good POCA newsletter article, a good Panteraplace item, and good for posting here.
Will likely tackle the rears first,as I want to install my Wilkinson stub axles and new bearings. No timetable yet, though.
Rear should go pretty smooth as I already have Quella's tapered bearing conversion so it should just be remove parts (No 700 pounds of torque on a tapered conversion), press out wheel studs, modify calipers?, install.
Yea, that's it. Should have both sides done some morning before lunch.
BWAAAHAHAHA roll on floor
Are these vented rotors the correct width to fit the OEM rear calipers?
Maybe not so applicable in your case Larry with the easily dismantled tapered bearing conversion, but for others with stock bearings why not move to a more modern rendition and move the hats outboard so that you don't have to strip the carrier/axles to replace a rotor. Aftermarket rotors and hats are relatively cheap, the cost in brake kits is the calipers.
Well, my thought is for owners that are willing to go for a low-buck swap like this, their priorities are probably cost first, future ease of replacement later?
Going to new hats with rotors on the outside is a great upgrade in terms of future rotor replacement, whether you keep stock calipers or upgrade them, too. But those new Mustang rotors are going to last on a street Pantera rear for how long? 30-50,000 miles? Why incur the expense (to get easily replaced rotors) for something that you won't be revisiting for many years?
And the stock rebuilt brakes, SS hoses and good Porterfield R4S pads have given lots of owners very good braking with stock everything.
To get far enough to do a hat/rotor swap, you've already taken everything apart. At that point, you just put everything back together with the Mustang rotors and total expense is about $150 plus some machine shop press costs. Can you get two hats and rotors for near that cost?
No not for $150 total, maybe for $150 a side using Wilwood parts.
In many cases going to the effort of stripping hub carrier/axle is going to result in replacing bearings, new axle nuts, maybe also axles in some cases. I suspect many owners would have this done at a vendor due to the torque specs invloved (that is a $350 a side cost), then it's worth consideration.
If you decide to upgrade calipers at a later date then you are ahead of the game. Just a thought.
Now , Now, Calm down fellas !! we can all play in this big pool !! Smiler
Not that I drive my pantera hard ( I am bit of a wimpy driver !!) are the brake discs an issue ? or is it for track days ? As mine seem ok, but when they wear out I may upgrade to vented discs if i can.
Being from 'down under' we have to make everything fit !! It's scary when people are saying I am the pantera expert !! Shows how little information we have on these beatiful cars !Lucky I am a hot rodder!!
Here my ongoing nightmare experience with the Wagner rotors:
I purchased a set of the Wagner BD60209 rotors twice. The first time they came in as a one piece rotor. The second time they were two piece but the disc was .91" thick. The stock Pantera rotor is .81 thick. The .91" rotors are too thick and the caliper will not fit on them. So I called Wagners tech line and they said the 60209 is for a'68 Mustang. He said the BD60208 were the right ones. They are a two piece seperate hub and rotor and the disc is .81" thick. So I ordered those. They came in .81" thick but one piece and made in China. I won't put cheap ass made in China rotors on my car, so they got returned.
My parts guy said he located some BD60208 rotor discs only (no hub) so I have those ordered and I am going to see if I can get the Pantera hub to fit on them. It looks like I may have to widen the center hole on the Wagner disc to fit the Pantera hub, but I won't know until they come in for sure. Of course this way I can use my original detomaso lug nuts. I had to special order these so this time they are mine and not returnable. Hopefully they are right.
Today I found a company who sells Disc-Italia brand rotors and they suposedly have sloted or sloted and drilled rotors only (no hub)for the '66 Mustang. I think they were like $240/pair plus shipping. If the Wagners don't work out I will pursue these, but I will not order unless I can talk to someone who has one in his hand and can describe them and give me dimensions. But I will let everyone know what I found out either way.
I would strongly recomend that you don't order the Wagner brand rotors because you don't know what you are going to get. You may get the good two piece, but more than likely your going to get the cheap Chinese ones. You are better off going with a better quality American brand like Stainless Steel Brakes or EBC from England
I apologize for getting this thing started. Based on what I had been told from one who had been there, done that,I was pretty sure my info was valid.
This has been kicked around a LOT on the POCA forum, and experiences have been all across the board.
I do know the SSBC units are one piece; I strongly suspect they are made in China. They will work, are the correct thickness but will require front lug nuts to be switched to SAE. They will also need a new dust cover to match what came on the Mustang.
I have a Quella conversion to Wilwood Super Lites using stock Pantera rotors. In my case, the calipers are for a thicker rotor, and to make them work on the thinner Pantera rotor there is a metal spacer plate behind one of my brake pads - this was Dennis' solution, not mine. For me, and any others with similar conversions, IF the Wagner rotors are too thick, I intend to mill / fabricate a thinner set of spacer plates to solve the problem.
Again for those of you who have been playing buy/return/buy roulette, I'm sorry.
My intent was to provide info on an easily sourced, replacement rotor for those with stock systems. Didn't quite work out that way. Frowner
Okay I know I've said it before, but why wouldn't you purchase a set of Wilwood hats and rotors? With all the uncertainty of the Mustang units, then added cost of replacing studs etc. you've almost bought yourself a set of Wilwoods, hats are around $100 and rotors $80 and it's a bolt on upgrade.
In your case Larry it'd be pretty crazy not to match the Wilwood calipers with a decent set of rotors. I can't understand why Dennis didn't do it originally.
Just my 2 cents,
If I am understanding this correctly the Pantera studs are too large in diameter for the Mustang rotors.
I personally have no problem using the Mustang studs BUT I would look to honing the Mustang rotor holes out to the Pantera dimensions. That's something that I can do and therefore it is fun and cheap AND I'll be able to get rotors for ever.
Now I just need to find a metric hone of the correct dimension. I'll bet it's 14mm.
No.
Other way around.
Knock out the Mustang SAE studs and the Pantera studs are too small. Welding steel studs to cast iron hub is a tricky weld.
And if they break, you then have a spinning lug nut and a bitch of time getting that wheel of.
What is the deal with this set up? I know it is not stock. I have seen them on other Panteras so they must be a vendor option. I was able to get a smaller Willwood caliper and a thinner rotor, bolt the rotor to the other side of the top had and move the whole thing further inside the front rim. Offset is actually pretty close and will help with scrub radius.
I don't see a Wilwood set up that would work with stock 15" wheels and stock calipers. You need a 11" rotor that is .81" thick and they have that, but the only matching hat for that rotor is a four lug hat. If you went up to a 13" rotor you could get the right hat but it won't fit with 15" Campys. Let me know if I am wrong.
Pantera Doug..........The Pantera studs are too SMALL for the mustang rotors not too big. Please see the pictures I posted.
Ian
Mine not only fit in the 15" rim but with the smaller Willwood caliper (same size piston) and thinner rotor I am able to move the rotor to the other side of the top (getting it further in giving me about a 1" deeper mount) and remove the spacer all together. I am using group5 wheels though. I will need to make a new brake caliper mount but that's not a big deal.
I will post some in another thread when I get a chance. I maybe hijacking his thread here a bit.
Sorry I was stressing a point and not specific enough. The Wilwood hat to use is the 170-0635 and Coleman make an 11.75 x 0.81 rotor (vented or solid) with the matching 8 x 7.62 bolt pattern.
Wilwood Part no#s for 15" wheels. This originally came from someone in the forum.
Some part no#s have been superceded.
Left front: caliper EG 120 31 91
rotor 160 38 73
hat AG 170-0635
Right front: caliper EG 120 31 91
rotor 160 38 72
hat as above
Left rear: caliper AG 120 31 93
rotor 160 29 01
hat GG 170 0635
Right rear: caliper AG 120 31 93
rotor 160 29 00
hat as above
I want to bump this to the top for some updating.
The Wagner #60209 Mustang vented rotor I initially posed to this thread was a number given to me by someone who said that item had worked seamlessly for his conversions, both front and rear.
I have come to the conclusion that number was provided in (an honest) error.
That Mustang vented rotor is for '68-69 cars. It is .94 in thickness. Panteras came stock with solid rotors measuring .81 in thickness.
My car has Wilwood Super Lite calipers, adapted by Quella. I was NOT able to use the thicker rotors on my car at either the front or rear.
My guess is Panteras with stock calipers will also have a no-fit issue with the 60209 rotor.
I now have four of them that will be showing up on eBay in the coming weeks. Sigh.... Frowner
What DOES work on the front is the 65-67 Mustang rotors. This is Wagner # 60208. The Stainless Steel Brake Corporation (SSBC) 65-67 Mustang rotor/hub combo (a one-piece casting) has been used by several owners ON THE FRONT and it is the same as the 60208. The bearings are the same but you will have SAE (not metric) lug threads and the stock Pantera dust cap will have to be replaced with a Mustang unit.
I have just found a 65-67 vented rotor ONLY (no hub) part number. I have two of them in the garage. I have installed them on the rear stub axles and they are a direct plug-n-play swap (uses stock metric studs) for the original solid De Tomaso rotors. They are however about 5/16" smaller diameter, which means the outer edges of the pads are beyond the edge of the rotor. I know that is not ideal, but do not think it is a problem?
Can anyone comment on that point?
That now gives me vented rotors on the rear for a total cost of less than $125.
I suspect they will likewise be a direct swap on the front De Tomaso hub/hat, but I'm not saying that until I actually do the fitment.
I wish for the sake of real comparison, that 2511 still had stock calipers. Because anything I observe is only for the circa '95 Wilwood conversion Quealla did in-house for a PO's full restoration on 2511.
I'm still gathering information on this from other owners and do intend to get it all down with text and photos when finally finished.
Just thought I'd update to this point.
And again, I'm seeking thoughts on the smaller rotor diameter and how that might be okay/not okay.
  • Picture_3
Larry,
Do your aftermarket Wilwood calipers use a caliper mounting adapter? If so you could modify that to move the calipers toward the spindle centerline.
Personally I would not run with the pad/rotor scenario you suggest, the pads will ridge, probably round over the edge of the rotor and at worst dig in and lock up a wheel.
I understand 'thrifty' but all this faffing around and you could have bought a decent set of rotors and hats by now a couple times over. When you already have aftermarket calipers & wheels why keep beating yourself over the head?
Originally posted by LF - TP 2511:
[QUOTE]Do your aftermarket Wilwood calipers use a caliper mounting adapter? If so you could modify that to move the calipers toward the spindle centerline.
For complicated reasons, modifying the existing adapters will not work. I will study the option of wholly new adapters, but am doubtful.
Because my mind is befuddled with liberal, communist, socialist propaganda? Wink
Seriously, there are many owners who do not want or can not afford to go the hat/rotor/adapter/wheels $olution.
As genuine replacement De Tomaso rotors are no doubt rare and priced accordingly, it seems a more affordable solution is a goal worth pursuing. I'm getting closer to doing that, and want to see this through to the end.
Perhaps next Winter, after selling enough GRP 4 tail lights, I'll just toss the whole shebang and go the full route as you suggest.
Yup, same thought I had. I have talked with two owners who also found they had an overhang issue. They just let it be and have not found it to be a problem.
Does anyone know if all four stock rotors were all the same .81 thickness? Where they all the same diameter? I've been told the fronts were thicker and the rears a little larger diameter, but my source said he may have been suffering from CRS syndrome.
Just looked at the stock rotors I pulled from #7024, one pair 11.1" dia. the other 11.7" dia, both 0.81" thick. I don't know which are front or rears now, but would have expected front to be larger.
Then you should be commended for carrying their burden and I'm not going to let politics slip into this thread any further....it's not in the 'Pub'Wink
Larry, to answer some questions, using slightly smaller rotors in the back will not be a problem, except for the maintenence issue of the outer edge of the rotor grinding a notch in the edge of rear brake pads. This is especially true if you're still using the toy-sized stock rear brake calipers because pad area is very small.
For those with too-wide Mustang rotors, why not cut down the pad thicknesss? Sure, the pads will wear out faster but you've saved so much over aftermarket Pantera rotors, you should still be financially ahead after a few years. The rotors could be cut down in width, too.
Stock '71-74 Pantera front rotors were about 1/4" smaller than the rears. Don't have the exact diameters available- something like 285mm and 297mm as a guess.
Finally, in mounting bone-stock Mustang rotors in the rear: was this done to the outside of the axle flange? If so, that pushes the wheel outboard by the thickness of the rotor's flange, and there are aftermarket wheel combinations that will then have fender clearance issues.
All rotor-swappers: keep in mind that a ventillated 0.81" or 0.94" thick rotor, on either end, will lighten your Pantera's unsprung weight, and will stabilize at maybe-150F degree lower temperatures, in street and light competition. Brake fade may be eliminated under these conditions. But for long, hard open-track events or possibly ORRs, rotors less than 1" wide WILL warp. Gr-4, GT-5 & -5-S cars used 1.25" thick vented rotors that're heavier than the stock 0.82"-thick solid rotors on '71-74 Panteras. Thermal mass is more important in competition than ultralight-weight rotors.
