I installed a set of NAPA shocks per the post below from Larry. In addition, go to Lowes and buy nylon bushings to go on each side of the "spade" mount, for the top and bottom fittings. Works great. I do not have a wing.
-----Original Message-----
From: fresnofinches@aol.com [mailto:fresnofinches@aol.com]
Sent: Thursday, February 16, 2006 12:32 AM
To: detomaso@realbig.com
Subject: [DeTomaso] DECK LID SHOCKS
All,
Just thought I would pass on some information on replacement deck lid
shocks. Found the part number on the P.I. bulletin board, installed
them tonight and the function is fine. Holds up my no-wing lid just
fine, closes easily, doesn't seem to be too firm.
Probably not strong enough for a winged lid. No information on
strength (pounds) of force.
NAPA part # BK 8195207 Compressed length of 10.34", extended length of
16.77".
Note the NAPA catalog image shows this to have different fittings at
each end, but this is incorrect. Both ends have the correct flat plate
with a hole needed for our application.
Total cost for two - $40.36
Peace, be careful but DRIVE IT!
Originally posted by Joe6pack:
Anyone installed the Vader lifts for the Pantera deck lid? I am thinking about ordering a set, but wanted to get some opinions. Thanks.
Are the Vaders spring operated versus gas operated? I believe the NAPAs are gas operated. I have the NAPAs and they work well - FWIW.
-William
