Hall Pantera has made many many great improved parts for our cars but this is not one of them.
quote:Originally posted by PanteraDoug:
It's just a steel nutcert. They are replaceable or very simple to replicate and replace.
Even bolts cross strip, i.e., wear out.
The simplest solution is often the best.
Nutcerts are often used for "blind bolt" installations on virtually everything.
I personally find the nutcert tool an indispensable item. I am on my third. I just wear them out.
All threaded fasteners need lubrication in assembly. The nutcerts because of the small bearing area are more susceptible to spinning and therefore really need just a drop of virtually any kind of oil in assembly. Anti seize compound should be used on something that may need to be disassembled in the future. That stuff never dries up.
They are a heck of a lot easier to do then welding a nut to a piece of plate steel.
If you think the nutcert sucks, wait 'till you try the original plastic plug.
True about "being screwed" if it breaks.
If you take a piece of 1/8" x 1" thick aluminum "bar stock", you can drill it a thread it with a tap.
Pop rivet it back on like your broken piece is.
That will be more reliable for you and almost as simple of a solution.
I did that on the trunk liner retainers rather than have the same issue occasionally like you have had happen.
That I did so I could switch to a retaining bolt (1/4" stainless button head screws) rather then the dzus fasteners.
It is almost the same plate you would be making for your armrest except for the thread type and size you pick.
What I usually do when using nutcerts is making a notch in the shoulder with a triangle file… that gives the inset the ability to bite ( essentially into aluminum) and a drop of red Loctite. Works for me for the last 25 years…
