Peter,
Is this front or rear or both? If you got new wheel nuts are you sure they are 12mm x1.5? It may pay just to get a thread gauge to check or die to run over the studs.
There's a slim possibility your front studs could be imperial, some folks were using front Mustang rotors as replacements and the 12mm studs are not a tight fit, as the rotors were designed for a 1/2-20 stud. It could be that the previous owner fitted the imperial studs to match.
Peter, what may have happened with the tight examples of your new nuts- the people who make these things may have over-plated the threaded holes inside, thus tightening up the threads. This has happened to people who pretty-up the rear swaybar by plating it; then the sphere-ball ends for the swaybar doesn't fit! Try running a tap through the new nuts and see what happens (assuming they are the correct threads to start with, of course!)
