My 1974 GT-L seems to be a bit odd! The windscreen wipers seem to be backwards.
Other normal LHD USA spec cars that I see when I google 'Pantera images' have wipers that park to the left and sweep to the right like the picture below.
Mine park to the right and sweep to the left. So when driving in the rain, the drivers wiper reaches perfectly vertical in front of the driver and then goes back again. This leaves the driver leaning into the centre of the car to see through the clear spot, or I suppose I could just close one eye!
This seems odd to me. Do you guys think someone may have played with them at some time? I don't think it's a re-assembly issue. It's like it had RHD wipers.
  • 9
I don’t recall the year but the wiper mechanism was changed to work like yours. I think it was to meet US DOT rules. If you look closely you will notice that the pivot points were moved to make this happen. They also fudged up the mechanism so they do not park well.
My wipers have not been used since I bought the car in 98 so I have no clue how well they work.
Mike
Seems odd to modify something to meet US rules but then they stop in front of the driver. I would think that driver's field of vision was of prime importance.
Just all wrong Mike. So to retrofit mine to a Euro spec so that it sweeps the driver side clear, I need 1971/73 components?
I’m pretty sure most all 71 cars like mine park on the driver side and sometime in the 72 model year they started the change. I’m on the road so I cannot check my car but I believe the pivot point might be welded to the car so making the change will be more than changing the grills. The park direction would need to change also.
Mike
  • MikesPanteraFV
You are partly correct, 1887; the factory changed the side the wipers park in response to U.S DOT regulations, effective with chassis 05900- early 1974, according to Tech Service Bulletin 14, article 113 (dated April 1975). The changeover described is complex: you'd need both wiper arms and blades, the wiper motor assembly, the guide tubes and pivot shaft for the right side, new support pieces, new cowl vent covers and a host of little parts. At the same time, they changed the wiper motor wiring including its circuit breaker and its mount. I suspect the car was built that way; NO one would go to that much trouble & expense to change over unless they had a second scrap car to move all the necessary parts over!
Robert, I'm no expert, I only re-assembled 1 basketcase Pantera. Here is a suggestion. Find arms that have less of a curve in them, so that the arms park parallel to the windshield moulding. That may change the angle in the line of sight issue. Even if you had a RH wiper set-up it would still go the the A pillar in the end of course position. So may be an adjustment in the mechanism,
Robert,
As Jack stated there was a changeover in late '73. The factory changed back again after the Ford era so later 9000 series cars (as per the GT5 phot you posted) are like early cars, presumably as they were no longer homologated for the US.
What you have is actually what most modern US cars have in terms of park and direction, but not the way the Pantera was designed, so it's a bit of a hack job to meet US regs. In theory it should work the best on a LHD as the other way you have an arc from the drivers corner of the windshield. It sounds like your wipers are not sweeping correctly, if all is correct the blade should align with the left edge of the windshield at full sweep.
This may be caused by having the wiper arm positioned incorrectly on the pivot, wrong arm or wrong motor or combiantaiosn of all three. From your photo I'd say it's the former as the Pantera wiper motor only has a 90 degree sweep arm, thus the parked blade should be parallel with the windshield. Yes this means it will park further up as per the 'stock' photo you posted and look pretty ugly.
Firstly I would stop the wipers at full sweep and readjust the arm so the blade is at the edge of the windscreen and then let is naturally park where it wants.
Other options include playing around with different wiper arms (shorter) to try and compensate and/or changing out the sweep of the motor. 5 degree sweep increments are available and I can help source motor parts if you need them.
Robert,
FWIW, On my 74L I run without the wipers but carry them with at all times. On the occasion when I need them I have to install the drivers side half way up the windshield parallel to the bottom of the glass in order for it to sweep all the way to the left side. Effective but looks terrible which is why I take them off on sunny days.
Doug M
Warning- wiper conversions may be injurious to your relationship! One owner that ran his own professional machine shop built a cantilevered single-arm wiper system similar to the Lambo Countach for his Pantera. He said it was the most miserable conversion he'd ever attempted, and even though he got it to work well, he swore he'd never do another. I couldn't even cajole him into doing a tech article on the job- it irritated him just thinking of the hoops he'd had to jump thru to get it to work.
Among other things, he found the body cowls are made of such thin metal that they needed heavy reinforcement to keep the area mounting the large single motor from flexing and cracking. And that was after he'd built his own linkage- 3 times- to get the sweep right.
