I have been working on an air cleaner which is the last item to complete a euro GTS and came up with this option.
I started with a K & N 11 in. Diameter 4 3/4 in. Filter Assembly. I removed the top canter filter area and installed a flat aluminum insert with a polished edge, painted and lettered to match the GTS wheel emblem.
The base was pressed to lower it over the carburetor. The major advantage using a 11" dia filter over a 14" dia. was it does not intrude into the deck but due to the 4.75 inch height, it is close to the 14 x 3 inch standard round as far as filter area (14 x 2.75)
I used my 2" raised engine cover to finished off the area. Cover still needs to be painted.
Thoughts and opinions are welcome.
Thanks for looking.
Kirk
  • Picture_429
A smaller diameter filter assembly is definitely a benefit.
Your engine cover is gorgeous. You know I think you have a wonderful eye for design.
I would think an air cleaner lid that reads "De Tomaso", "351 Cleveland", or "Pantera" would be more widely accepted. I personally wouldn't want one with the K&N logo on it.
Another current fad is to have a threaded nut welded to the bottom of the air cleaner lid, instead of a stud poking up through a hole.
Thanks for the input George. I did not enplane the project well.
Started with a K & N off the shelf filter with the filtered top. Then removed the filter area, free handed the new 9" center, polished the edge, taped the edge, bead blasted the remaining center and shot it with DP-90. Then installed the GTS to match the car's Euro GTS pedigree. The center bolt was a SS flat allen head recessed into the lid so I could keep it white using the original GTS emblem material.
The trick was to lower the base because it is raised. Looking for something that would hold the outer filter surface flat and allow me to press the center lower took some looking. Got lucky by using a rear Pantera rotor which was the correct DIA and held the filter mating surface flat and then used an old Pantera axle with studs which held the axle in the center hole and then pressed it down. It worked remarkably well to lower the filter overall.
Removing the filter was a project though. It was glued in with what appeared to be urethane windshield adhesive---it was a bitch to get it out.
One could build the entire top using a thicker 11" blank and turning the filter area into the bottom and then machine in anything you want if your pockets are deeper. This was an effort to make a smaller filter not intrude into the deck and keep it as low as possible.
The 9" new center can be made in any look someone wanted just buy having an emblem made which is a bonus for individuality.
I have fought with filter ideas and shapes for years and the reason is a story by it's self. Air flow was explained to me in depth by someone with allot of racing history and why things work better or not. I sat in his office for several hours and talked about his history which I'll never forget---great guy.
  • knn-66-3120_ml
Doug, that's the base I have. It would clear side hung floats I think, but center hung floats require drilling a hole (that very conveniently ensures it's not put on in a wrong angle)
BTW, for my Longchamp I needed a lower base, I never found one that would just fit, I found one that fit with an hour of hammering and modifying the filter element slightly. Strange nobody produces a tea-cozy for a center hung Holley?
Originally posted by Kirk Evans:
With a very tall cover. This car had a Parker Funnel web intake which is quite tall.
Kirk, on the tall cover for the Funnel Web, is this all 'fab'd out of sheet metal or is this done in fiberglass?
Do you have a picture of the front of this one (against the glass)?
I like what you did with the screening but I'm still stuck in trying to find a source of the original silly Italian screening.
LOTS of great thought process here by everyone on an item with massive design restraints.
Offset base is nice Mikael---and no worries about adding my threads. I want the input and ideas/products. Any idea when the offset Spectre was first available? My first offset build was many years ago so it is patterned and easy to duplicate but I will use the Spectre part now--can't beat the price--thank you for the heads up.
Nice tubing work Chris. It is certainly good to find fresh air. I have only made a few direct scoop ducting applications over the years and they have all been different designs for different induction systems. Your approach looks good and is far simpler.
Here is a picture of the last one I did years ago. It was difficult to build.
  • Picture_3564
It is all steel Doug. Here is a better shot of it. The entire front is open because you can not get it over the filter and carb. You can see through the cover which helps a bit backing up. Not sure why I did the top in that screen configuration---probably had something to do with the remaining left over screen size and I wanted to see to see the Hall air cleaner details.
The screen is available on line in steel and aluminum. The 2 inch cover has a fiberglass top, aluminum screening and a 14 gauge 1.5" wide steel perimeter which holds and screen better, holds the front and back edges straight, keeps the side curves correct and reinforces the hold down screws or fasteners on the sides so they do not decay the glass.
  • PHTO0023B_(18)
Great Mikael, thanks. Been out there for a while. I never understood why one of the MFGs did not make this years ago.
This one presented a different problem so I made side screens to keep the injection fully visible. The biggest problem was creating a support that would hold the weight. I made a cover for the original mount that served as a new support for the screens.
Here it is in the raw. I recently decided to do a story on this build form years ago. This car was such a mess, WOW! Great shape now though.
  • Picture_34613
I spent a bit of time myself on similar "projects" as all of you have.
I actually really love all of the solutions posted here. It's all food for thought.
I'm wondering how many times each of your solutions needed to be remade Kirk? Trying to get through finally without and screw-ups, then "Dam!Look at that! I can't leave it like that! Dam!" Roll Eyes
To everyone, as the 'Southern Evangelist' MIGHT say, "Brothers and Sisters...I feel your pain".
I truly do. Wink
The screen all framed up with the mounts made. The angle on top of the side covers is at the top of the deck surface. The screen is raised and the bottom the screen follows the deck surface also.
So this is one project seeing the "design as you go" approach.
Mozart I am not---no writing down the music without mistakes, many mistakes.
  • Picture_wayne_(37)
A view from the deck.
This started as a small air cleaner that could fit the car and still offer enough flow. The reason behind this is once I was fortunate enough to roam a shop and sit in an office of the man who was a well known creative engine genius who helped design the Holley four barrel most of us run. During the hours of fantastic stories including flying 50 plus WW2 B-17 sorties, he started talking about how air enters a carb and with many hours of dyno testing, the simple velocity stack was best to correct the shape. He explained that you need at least 4 inches of height to help the air re-shape and enter the card correctly especially "at speed" in his words. He said the best working air cleaner was the large diameter open on top type---looked like a giant stack with a foam filter. He said it didn't do much to clean the air but was great for "shaping". He explained the best air cleaner to use was not practical because it would be 8" in DIA and a foot tall. Next best option is a 10 to 12 inch DIA with at least a 4 inch gap from the top of the carb. He gave me one of his velocity stacks along with a proto type dry sump pan from the 50s---one of the first ones he ever made.
Of course the only way to prove this is to, in his words "dyno the same engine 5 times minimum the velocity stack and the air cleaner back and forth and measure the HP-Torque drop---10 runs minimum to get a real comparison.
In my case gaining a 1 or 2 HP is not the issue so if any of the air cleaner talk input helps someone, I hope I did my part. Thank you all for the additional ideas and support.
  • Picture_3571
