Wow. No one ever RECOMMENDED me? I've had guys come looking for me with a shot gun but that's another story.
Compcams has a listing on the 289hp Ford for a hp stock cam plus 1.
I didn't look for it under the cleveland heading but I think essentially that is what you want in your car.
The stock CJ cam is good to about 6,000. Maybe 6,200. Then it just shuts off BUT it has a nice idle and a nice burbbly sound to the exhaust.
Yours is what the manufacturer called a 268. There is no such term to qualify the CJ cam so that you could compare but you are likely into a 280 to 282 advertised duration.
A hydraulic lifter cam with 350 pound springs will let you rev it to the 7,000 rpm area if you so choose but in a street cleveland that isn't neessary at all.
Look at the video in the other thread of the blue car on the track. That car has Webers and 180 headers with open exhausts.
I don't think I saw it go over 6,700 rpm's.
It just isn't necessary unless you were trying to beat one of the factory teams and fat chance at that. They have mega bucks.
Why don't you check in with the CompCams tech help line and tell them what you want and see what they recommend. Bet cha' a nickle it's what I just said.
I have noticed that they tend to recommend about a one notch calmer cam than I would.
Don't be afraid of something like a .580 lift. It won't hurt anything and will give you the top end that you are now missing.
Incidentally, the Webers get 22 mpg and the Holley about 14. You can make them run on regular gas too.
The ONLY place your cam would save you gas is at the 550rpm idle it's got. That's all.
What George has said in the past about these aftermarket cams being used in everyday traffic being uncomfortable is absolutely true but are you going to drive this car everday in traffic like we did in the 70s? I doubt that.
This one is about what the stock CJ cam was.
http://www.compcams.com/Compan...s.aspx?csid=842&sb=2I was thinking this one would be about a +1:
http://www.compcams.com/Compan...s.aspx?csid=843&sb=2I am using this one even with the Webers but you would need to be somewhat of a dysfunctional sociopath to use it:
http://www.compcams.com/Compan...s.aspx?csid=861&sb=2
