The bottom of the pan is drop all the way across there is no sump like a traditional pan .. its anodized color and if you drain the oil you get 10 quartz out of it ... had to add that ..LOL
joules"Racing is Life, anything before or after is just waiting" - Steve McQueen
For anyone ordering an Armando pan, I beleive he stopped adding the Temp sender bung unless specifically requested, so be sure to specify if you want it.
