I am doing a new panel and have not found an O.E. style ballast resistor. I noticed they were a 4 prong unit. The only 4 prongs are chrysler units. Any advice is appreciated, thank you.
No problem. Thanks again for you resistor. Working on the electrial system. Still trying to find the electrical portion of the ignition switch. Larry wants $1,475.00 for one.$$$
