It has to be going somewhere. If the engine is running, and you are loosing fluid, then it's the master has a leak and the fluid is getting sucked into the vacuum system, through the vacuum booster.
That is a common failure of a master as failures go but not on a new or a rebuilt one.
Best get on the horn with Wilkinson and ask him WTF. Big Grin
