In the constant examination of my car for more room, it occurs to me that the bake pedal piston rod can be shortened in order to put the pedal closer to the front bulkhead.
Now at first this might seem a radical statement to some of you but it looks like the pedal could be moved about two to three inches further from the driver.
Now if you look cloesly at the stock footbox you will clearly see that there is about four or five inches clearance from the bottom of the pedal to the front bulkhead at full travel.
In my car, and I presume all US production Panteras as well, that would place the brake pedal and the accellerator pedals on the same plane and enable heel/toeing.
The clutch pedal can't be altered since the Pantera clutch needs every bit of travel it has now.
This is something that the Racers must have already discovered. The question is how much forward can the pedal be moved safely?
Any ideas anyone?
