The damage included som bend metal in the upper shock/suspension tower frame, which had to be bend back into place.
Impressive fabrications skills! Sure wish I could do what you and so many on this forum are capable of. You're an inspiration.
Thanks again for providing photos of your progress. You are an inspiration.
Thanks for the comments - that's motivating. And I need motivation as there's still a long way to go.
In all honesty I look forward to finishing the metalwork. For me this is hobby - I'am not a professional metal worker. However, with a lot of attention to detail, patience, A LOT of time and a few of the right tools it can be done to a fairly high standard. Also, having a friend that can fabricate the more complex metal pieces (outer rocker and inner B-posts) helps too.
Like David fx has with his project XXXX, I'm beginning to form a vision for this car as well, allthough it's a lot more traditional and not so creative. Stay tuned for that.
Wow! That is really fantastic work. Very impressive.
I love to see threads like this. It empowers more people to try things. When they can visualize what is done, they are more likely to try something themselves even if on a smaller scale.
In every project it is only as hard as the hardest task. The difficulty is keeping perspective of the task.
I find that most people can do even some of the most difficult task; they just don't know it. "Will" and "interest" are of the most important required skills.
I find if I beet my head against the project long enough there is little one cannot do; but only if the will to do so exist.
And btw, Nice job!!
Push, I know I've said it before it this thread, but gotta say again... "impressive work man".
For the record, I totally agree with Comp's remarks. For me it's always worked, visualize and do. Worst that can happen is the need to re-do. Sometimes I wished I had visualized longer..or even sought out more advise first. But threads like this are great to share.
Kristian, What is the right tools?
Anders, I basically only use a welder (MIG/MAG and gas-welding) and a metal bender, heat and a number of different handtools. As I said, for the very difficult fabrication that need an English wheel or other advanced equipment, I turn to a friend. However, the pantera is for the most part not too complicated to make parts for.
Got a Little Work in over the weekend.
Removed the lower front a-arm mount for repair, it had been replaced at an earlier time and had to be re-adjusted for the correct chassis measurements.
Kristian,
You are doing an amazing job. I must say, I hope you are patterning all of these parts because it almost looks like you'll be able to construct a Pantera unibody from scratch by the time you're done! Thanks for posting your progress. It is great to see everything in such detail, so well lit and photographed.
Mark
Mark
quote:you'll be able to construct a Pantera unibody from scratch
Ha, Ha! I think not
The only parts that were patterned are the outer rockers and inner b-pillars.
I'm actually almost done, now working on the last section of bodywork. I "just" need to finish the left front, re-mount the fenders and then the chassis is ready for the painter.
It's going to be the original Gr4 red - anyone know what color that was? Maybe the same orange-red that the ´71-72 production panteras recieved??
I decided to use the design of the early, early cars for the front box-structure reinforcement. This is one large bar, compared to the later smaller triangular pieces. This bar sits between the front a-arm mounts and also closes the box structure up somewhat, thus providing af stiffer and less flexphrone front subframe.
It's a true copy of the original design on #1267. I added several drains at the bottom. Here is the bar being fitted
Wow!
I love all your work. Your attention to detail is incredible. I'm curious,though, what do you do for a living? Are you a body man, engineer, mechanic, sheet metal worker?
I have felt that front "box" would be subjected to the same abuse the rear member recieves from centerline floor jack lifting.
I don't know if it does given there are fewer reasons to lift the front end, but that is one area I would like reinforced during rebuild so it could be
That's a great idea. I find the front easily gets as much lifting as the rear. The problem is, unlike the rear plate, it's much harder to get in there even with a super low floor jack.
In that area I removed my tie down tabs and set it up for removable eye bolts.
OK, the decision has been made - it's going FIA racing !! The Cage is from Sassa in Italy and fully FIA certified.
was the roll cage expensive?
Is there any holes on the plate under the radiator that water can drain out through original?
I discovered a lot of "crap" on my car when I took it apart.
I'll make drain holes on mine. I begin with sheet metal work hopefully this weekend...
it is a lot of crap
no wonder it rusts
Anders, the roll cage was 550 euro incl tax but excl shipping. Shipping was around 150 euro to denmark.
Most of us concerned about chassis rust drill 1/2" OD holes in the extreme bottom of both legs of the 'horse-shoe' stamping that supports the A-arms as well as 3 more in each main rear frame rail. Drilling the chin piece below the radiator is a good idea, but due to the shape of this piece and the 2 degree nose-down rake recommended, the hole placements needed is not at the back but about half-way forward in the curved area. Leaking OEM thermostats and hoses have ruined many of these parts (now reproduced by Johnny Woods in England).
Removing the damaged support pieces.
These extra bars were actually added by Ford/detomaso after the first crash tests by ford - to protect against frontal impact and get the chassis to pass the impact tests. They are not present in the original design and fx #1267 does not have them. Thought about leaving them out for minor weight savings since they have no structural purpose in terms of chassis rigidity. In the end I left them there but did them in the thinnest sheet that I had.
Here I removed the damaged parts
I enjoy watching your progress and approach. Nicely done - please keep sharing.
I was thinking holes in the box would look good, but be a lot of work...but I guess a "lot of work" is not a problem!
are they punched or cut?
JFB, I'm not sure what box you mean, but yes, in the front, the factory Gr4s had holes stamped in the upper curved crossmember and the lower radiater support for fatique strength (and a little weight savings).
I thought about replicating this, however, since the structures are closed now, holes cannot be pressed/punched to create the edge thickening that is important for strength.
Drilling holes and then bending the hole edge may be possible using heat and a taper tool, maybe? Haven't figured out how.
No time to celebrate - moving on to the driver side center structure - need to fit and install the outer rocker. First some trimming of the b-piller and experimenting with adding strengthening and wenting holes on the rear part of center rocker and b-piller.
What an amazing reconstruction thread.
Skill level is amazing.
It would be fantastic if some of those awesome parts could be produced for sale to others.
Nothing looks easy about it. Congrats on several impressive achievements!
Actually the B-post is produced by Johnny Woods in the UK. He has them on e-bay.
Yup;
http://www.ebay.com/itm/DE-TOM...-panel-/230634449121
Hi Push,
Looking good man.
"This may look easy, but it takes an incredible amount of time to make sure everything fit and align as good as possible"
You said it man...!! It's amazing how long it takes to make it right. And it looks like you are getting it right! Congrats on the progress.
Looking good man.
I've started to accumulate the parts I need to finish the chassis for the painter. That included the gr4 flares, aluminum door skins, the roll Cage and the WHEELS.
Here are the Wheels - a set of 10 and 14 inch Gr4 Wheels !!! Crazy stuff. I need those (and tires) to set the fender flares.
Looks great! Love those wheels!
Which source did you use for the wheels?
Wheels are Marvic magnesiums
Duuuude....the wheels look awesome..!!
Oh... forgot to comment. The latest project pics look very nice too. Bang up job man.
Sign In To Reply
