Hey guys,
I thought I would provide a review of the cable shifter conversion that is offered by a sponsor of this forum, http://www.saccrestorations.net/
I had kicked around the idea for awhile primarily because the 42 year old mechanism in my car was progressively fighting my efforts to shift smoothly, and enjoy the car. I had tried all the usual quick fixes like replacing the trunnion bearing, removing the detent at the shifter, replacing the shifter handle, and machining the fingers out of the gate. Faced with the more difficult things like replacing the u-joints and replacing the bushing at the trans shift housing, I decided to go the cable route.
I'm glad I did and did not listen to the negative voices found in a forum search. There are a lot of detractors of the cable shifter conversion for some reason, and those detractors do not have a system in their car, or are commenting on the early unit that Lloyd B. developed. I think an updated thread is in order.
I can tell you that I have the latest from Scott Bell, and it works beautifully. The feeling through the gears is crisp and positive. The ability to make adjustments and lock them is dead simple, and the total install can be done in one Saturday afternoon if you are good with tools and know your way around your car. Faced with an old and worn original linkage, this is a valid and great alternative.
Note that the new shifter fits with the original console trim, and the bracket that is bolted to the ZF will still allow the use of the fiberglass trunk liner. You do loose the backup switch and light function, but a clever guy could adapt a different switch (my future project).
You will need to remove the center console to gain access to the sheet metal just aft of the shifter for a new bracket. I was able to lift up the console at the rear instead of removing it altogether, saving a lot of hassle. You will also need to make simple bracket to keep the cables tidy in the engine compartment. A couple of pix:
