First, Can someone tell me what spec. whould a factory cam have in a 1982 pantera? duration, lift,RPM range. And how much should I gain by using a lunati braket masterII kit, the cam is 224/234 at .050, gross lift 536/562,RPM range is 2000-6000.
The car now will reach 6000 RPM on all gears, I dont know if the RPM reading is corect or not.
The engine is a 351c,4v heads, headers, edelbrock manifold,holley 800dp, MSD-6AL,I will find out what pistons are in when I pull the engine out, I will use forged flat top if the pistons in the engine are disched.
Second, will a high volume oil pump and a hard driveshaft solve the oiling problem is the 351c? I can not use oil restrictors because I'm still using hydraulic cam.
Thanks for any advice.
Hani
What cam might be in there is unknown; all US-spec 351Cs ceased production in 1974, so your later car probably has an Australian-sourced Cleveland, or possibly a rebuilt US unit. The Aussie engine is usually an advantage but I have no idea of what cam they used. You'll have to pull the cam (it can be done with the engine installed) to I.D it and even then it may be unidentifiable. If you absolutely know-for-sure that the engine has never been opened & messed with, I'd enjoy the car as-is, and order a new cam, lifters, valve springs and pushrods when it begins to soften a bit (and running it to 6K regularly will do that....)
I've been reminded that DeTomaso put non-stock parts into some of the later engines, so all bets are off re your present cam. I always recommend calling the cam grinders Help Line and getting advice from the people who make them for a living, when shopping for a cam. But in my opinion, the cylinder heads you have will dictate much of what parts you can profitably use. For instance, you will probably not have dished pistons, even with closed chamber cylinder heads, nor should you use them.With iron closed-chamber heads, you can get away with 10:1 compression ratio as long as you run a cam more-or-less as you mentioned. Such a cam will bleed off cylinder pressure at low engine speeds, and at high engine speeds cylinder filling is less efficient so pressures never go up to the detonation-point. The engine doesn't care what the ratio is, only the physical pressures. Just be sure to use matching valve springs and discard any multi-groove valves, as they will be stock welded units that will fail with extended hi-rpm use. With open chamber heads, you have a less efficient chamber and 9:1 is about all that can be used. This last will probably call for DOMED, not dished, pistons. As far as oiling mods, a completely stock oil pump works fine, and remember there are two different kinds of oil restrictors in the kit- those that go into the cam lube passages and the single one that restricts the left-side lifters. By all means use the 4 that restrict oil flow to the cam but discard the one to the lifters & you'll be fine.You should end up with 25-30 psi at idle & 60-705 psi at 3000rpm, with the engine hot. The stock gauge reads about 1/2 of reality, BTW.Your 800 CFM Holley is meant for extreme top-end running or drag racing. I recommend a 600 or 700 CFM, dyno-tuned to the engine. This makes the engine more responsive & fun to drive at low speeds while only giving away a few horses at the upper end, and gas mileage is also more reasonable. I got 20 mpg with my 700 on a recent 900-mile trip.
Thanks Jack
I think the best thing to do before buying any parts is to wait untill i pull the engine out and see what's in it, i do have a 650 dp which i will tray soon,
Thanks again
