You guys have done an AWESOME job with your Pocono get together & what you've done with that trailer is just unbelieveable!! My hat is truly off to you for all your hard work & planning in bringing together so many Pantera brothers for this event. Only wish I was closer to you guys & could join the PARTY! Now just go & kick some A**, show off that trailer & have as much FUN as humanly possible!! Good Luck to you all!
Dennis,
The trailer has two independent lifts controlled individually and fixed upper and lower rails in the front. It works really well. Our very first trip last week went off without a single problem. And it wasn;t even finished. A few small adjustments being done now will make it easy to operate for one person alone and reduce the time to load and unload.
Check out more about it here:
http://pantera.infopop.cc/eve/forums/a/tpc/f/1550045562/m/6120012945
  • 9420012945_IMG_1292_2
