There's a small light bulb wired into the same harness as the cigarette lighter. It shows up in the wiring diagram as what appears to be a combination lighter and light. I assume this to help one find the lighter hole in the dark so one doesn't brand one's vinyl with a hot lighter. However, I can find no way to attach the bulb to the lighter barrel. Is it possible my original lighter assembly was replaced?
