Cleaning out my collection of parts
Selling the following:
New sb ford stant thermostat 45358 (not 351c)
New Ford motorsports valve covers– installed, never run
New full roller timing chain – installed, never run (make unknown)
New Camonics cam shaft– installed, never run
New set of TRW L2416 forged pistons .030 8 cc dish on reconditioned rods– installed, never run
Used, original parts
4V exhaust manifold set
Water pump pulley
Fan spacer
Used distributor, 1974 era ford electronic
Misc accessory brackets
Stock front sump oil pan
Water pump front cover – cleaned, painted gray, ready for install
1970 D0AE 4V closed chamber heads – bare, need full rebuild
Used, with a bit over 3000 miles of use:
Stock crankshaft .010 under, needs to be turned again
Complete set of 2 bolt main caps
Crane cam shaft HIT280
Will be periodically updating this list as Items sell off
Items are located in Livermore, CA
If interested in anything, PM me or email Mustangpartsjp at gmail.com .............Jason
